- Joined
- Sep 16, 2012
- Messages
- 8
- Reaction score
- 0
I joined this forum a month or so ago and got some great advice on looking for a small keyboard with loads of sounds. I ended up going for a Korg Microstation which was an absolute nightmare to track down as I found out they were discontinued. I finally found somewhere in Glasgow that had a display model tucked away and got it dicounted 20%, so all good! I really like it, but have a question on the drum editor if anyone can help.....
I appreciate there is an on-screen grid editor, but lets face it its not that easy to use. I've installed the bundled software which lets you change all-sorts of parameters, but i thought it would have been great to have the grid sequencer as part of the software, but just can't see it.
Does anyone know if you can do this? Am i just missing it, or is the grid-function limited to the on-board sequencer.
thanks!
thanks!
