- Joined
- Apr 26, 2019
- Messages
- 584
- Reaction score
- 158
Long time no see...
I've been having some fun with my ES110 in my mini amateur home studio, using it together with a cheap Novation Launchkey midi controller. I'm using Cubase as my DAW.
However, I would like to expand my 'horizons', as they say, and replace that Launchkey with something 'beefier'.
I used to own a Korg Kross 2 88 and I must admit that I liked it a lot, so my attention automatically turned to Korg.
The Nautilus seemed like the obvious step up so I've been looking a the Nautilus 61 a bit closer. As said, would like to combine it with my ES110, which I would continue to use for all the piano parts and just use the Nautilus for some extra fun (I briefly considered replacing the ES110 with a Nautilus 88 but I guess I'll have more flexibility with two boards). Moreover, it has editor software which you can use as a plugin in your DAW, something the Kross 2 has as well. I admit, the thought of getting the 61-key version of the Kross 2 'crossed' my mind (no pun intended) but seeing that the keybad of that board is plastic fantastic, I decided against that.
So, the Nautilus. A question about pedals, too.
Seeing I also have a Focusrite 4i4, how would be the best way to connect everything, so that I can have half pedaling from the Kawai playing the Nautilus' sounds ?
I would like this to work when I'm using the DAW but also when I decide to just use the two boards without a computer.
As usual, perhaps a stupid question, but any feedback would be appreciated
