Korg Opsix on Logic Pro X
I use a Korg Opsix to control the software instruments in Logic Pro X via USB. This works without any problems.
I can also add the Korg as a midi instrument in Logic and see that when I play the keyboard, the amplitudes in Logic go out. Unfortunately, Logic does not output any sound from the Korg.
How can I access the sounds of the Korg with Logic? Do I also have to connect via the old midi cables + midi interface? Thank you for your advice.
