Korg Pa4x Eq settings please
Like the title says im looking for other pa4x users eq settings to try on my own setup and see what the best one is. I dont really know that much about eq as in the past I have just boosted everything until it sounds somewhat clear with just enough bass. Can some pa4x users please help me out?
The Eq on any Pa is not a one size fits all feature. Once you enable the Eq in Global you can select one of the six already set up ones from the drop down menu. These six are not fixed and can be adjusted to suit the environment that you are playing in.
The 4X has the MaxAudio feature which operates slightly differently, P538 of the manual describes how to use the feature.
Like the other Pa models there is no one setting solution, only the setting that best suits your playing environment.
