Korg pa700 set file not working on other pa 700 keyboard
hello,
i got a file from someone for my korg pa700 in the middleeast, after i put it on a usb and put in my keyboard it works fine.
i tried to put the usb on my father's korg pa700 and it wouldn't load everything and a warning sign came on that said not everything has been uploaded since it might be "copyrighted" and to insert the orginal usb with the file.... is there a way to fix this issue so it can work on both keyboards?
Please DO NOT Solicit Copyright Material or request how to break copy protection on these forums.
Thank you
There are slightly different versions of Korg’s OS depending upon the market which you are possibly experiencing an auto response.
That said bought Packs will be for a one off keyboard and are not for sharing as Gary explained.
If you Google .... Korg Bonusware.
You will find 40+ Style packs available foc.
Additionally visit Korgworld.co.uk for even more free resources.
Rajitha
