Does this sucker have proper DIN MIDI ports?
If it does then you are in luck.
Buy a $20 USB MIDI Interface and use the DIN ports to connect to the PC.
Buy FORE MIDI to USB Interface MIDI Cable Adapter with Input&Output Connecting with Keyboard/Synthesizer for Editing&Recording Track Work with Windows/Mac OS for Studio USB 2.0 Color Red - 6.5Ft: MIDI Interfaces - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
I'm guessing this is an ancient vintage keyboard so even if there was a driver for the USB port a decade or more ago it probably wouldn't work on any modern operating system.
DIN MIDI ports will work just fine as a workaround. It just won't show as "Kurweil" under device manager. It will be something like Class Compliant Audio device.
It's Plug n Play. No driver required.
Then you can work with it with any MIDI software you choose.
