Kurzweil Mark 10 problem
My Mark 10 has an issue with the grand piano button. It works but I can’t switch from one instrument back to grand piano. I have to turn off the keyboard and back on for it to return to the grand piano. Can this be fixed?
The button is probably shot; I don't even know if a replacement button is available for purchase in the aftermarket. I believe the Mark 10 was introduced in the early 90's so it is close to 30 years old. If there is a similar type button on the keyboard that you don't use you might be able to get a tech to swap buttons with one that you don't frequently use or don't use at all. This way the bad button would control a function that you rarely use and the grand piano button would be fully functional.
Please refer next blog title 3.
It's a Korean blog.
So you have to use the translator in chrome web browser
