Lazer gun type of sound but in pitch
Wonder if anyone can help me.
49 second in , what kind of sound is that? Like it pulsating pad or a kind of sound effect? That many sounds the choose from
Thanks
Should be able to do it no problem. Assign delay rate to a slider or mod wheel to do the latter part of the sound, where it becomes a percussive buzz.
My other hand is busy playing something else at the time so was hoping it would be a simple press of the note (G) while continuing with the song?
But honestly I don't know Roland's VA synth well enough. If you could tie the delay rate to the envelope that would work too.
There's no aftertouch on an FA, right?
I don't think so. Only pedal I have is sustain like the piano or holding the strings.
Got the modulation switch as part of the pitch bend knob.
Yes can get a second pedal.
What im doing usually is just assigning the funny sounds to one section of the keyboard. There's a few candidate that are similar to this pulp sound and im playing about with the settings and gonna save it so it's ready. Don't really want to use a pedal for the sound as I'd prefer it was just ready on those notes.
