Limelight By Rush, Midi Sequence
WI USA
This one turned out ok i gusse, I "finally" found a decent source for Rush Midi files, The orignal file sounded better than some others ive found in the past.. I spent about 5 hours totally revoicing and mixing the sequence and mixing the vocal (Geddy Lee) real time from the PC threw my mixer. All instrumentals / drums are from the MX61. Had hella time getting the EQ to sound right for You Tube, so adjust your systems acordingly.. ;)
Similar Threads
Rush sounds for FA-06 1
RUSH keys sounds 4 Roland XP-80 1
Rush and Keyboards 0
Rush... how do they do it? 7
