Looking for a spare part for Technics SX-KN1400
Hello,
I am looking for a spare part for this component (don't know how it's called), maybe you know where can I find it ?
Thank you,
-- Leon
Zolder.B
Hoi
On the internet : synth-parts.com or ebay or type in spare parts for Technics keyboards.
The KN6000 has a similair button (number 46 in the manual)
In the photo the button does not appear to be damaged, so it maybe blocked.
You can try opening the lid and clean or unblock the function parts under the button.
Succes
Mris
Hoi
Succes
Mris
Thank you.
"The KN6000 has a similair button (number 46 in the manual)"
Do you think it's possible to use this one instead of the one that I have ?
Or "similar" doesn't mean "replaceable" ?
Zolder.B
Thank you.
Hoi
It is NOT replaceable.
The info from ebay indicated a DIAL KNOB
Circled in red in your photo is a PUSH or TAP button.
Similar on the KN6000 means there is a likeness button used for styles and favorites.( push or tap button)
Is there any movement on the screen when you push up or down that button.?
Will this be helpfull.
Mris
Rajitha
