I'm stumped. I have unfortunately a budget of < $1500 US. Here are the features I want.
* weighted or at minimum semi-weighted
* 76 to 88 keys
* half-damper and full damper function
* expression pedal
* modulation and pitch bend wheels
* its own internal sound bank with speakers or at minimum external speaker capability.
* if it has its internal sound bank I'd like it to be tunable.
The closest I've found is the M-Audio Pro Keys 88, but that one doesn't support half-damper.
I constantly use the damper pedal on the piano in the 1/4 to 1/2 range but very rarely full. I'd like a keyboard that does this.
The other one that would work is the M-Audio Axiom Pro 61 but that fails because it's only 61 keys. I want 76-88 keys. I could get by with this if it had more keys. I suggested they consider making an Axiom Pro 88.
Does anyone have any suggestions? Or.... does anyone know of a way of modding the Pro Keys 88 to support half damper?
FYI: I use Pro Tools M-Powered 8.0.1 for my DAW and use a M-Audio Fast Track Pro interface. Reason 4 and Alicia's Keys at the moment. I may get Komplete 7 next year.
* 76 to 88 keys
* expression pedal
