M-50 some tips for sound making?
I have a problem with sound making.
Example i have made a powerful string sound for live performance and after string part comes piano part. Problem is that after that string part piano is very low in "volume" like volume stays at same level but sound it self is quite lower. How do i fix it? is there better way than start going trough million live combis and make all strings lower? or is there possibility to make whole combi to be played at lower level?
Yea there is. Use EQ filters or stereo compressors on one of the effects.
That usually does the trick. Just route the piano sound (i guess it's inside the same combi) through one of the limiters/compressors/EQ filters (depends on your structure)
Or if you spent all IFXs on your strings, just have a MFX with one of the compressor effects and send the piano to MFX1/MFX2 up till it's loud enough.
The other solution would be to lower the strings volume, boost the piano AND
boost the master keyboard volume up... but I don't recommend that.
You have 5IFXs, 2MFXs and 1 TFX - use them :)
Mendelw
