using an M-Audio 61 MK III midi controller which has both a USB midi and a 5 pin midi output in the rear.
I want to use the Controller to also send midi to a KORG PA4x arranger which receives midi and outputs AUDIO into my Audio interface.
I run the USB 2.0 from MAUDIO directly into my MAC and my DAW software instruments work fine ....
Can I send out midi from the M-AUDIO KEYSTATION 61 using the USB 5 pin MIDI connection/cable to the KORG PA4x and without moving things around control both the DAW and just sounds from the external KORG sounds?
i.e. control the DAW and sounds from the KORG PA4x
Thank you very much
Thank you very much
