M audio keystation mini 32 mk3 pitch bend issue
I am very new to midi keyboards and when i was using my keystation mini 32 mk3 the pitch bend keys just suddenly stopped working.
I am assuming i did something with the edit button but i cant seem to reset it back to default. Any suggestions?
Not sure what you did either, save your presets to some medium like a usb, computer, etc. then reset the keyboard:
  1. Power Off the Keystation.
  2. Hold down the buttons ADVANCED, OCT+, and OCT- simultaneously, until step 4.
  3. Power On the Keystation.
  4. Release the three buttons.
Try the pitchbend to see that it works. if it now works as expected reload the presets, then retry the pitchbend, if it stops working again then you know it is something you did in one of the presets.
Sorry for the late reply, but perhaps you're thinking about another midi keyboard? Because it dosen't seem like the keystation mini32 mk3 has an ADVANCED button. Could you clarify?
tc4m
