For live performance, Mainstage is basically a combination of two things: (1) A program that allows you to manage the routing of your MIDI keyboards to play/split/layer different hardware and software sounds at different times, and (2) a library of actual sounds that you can play. On the iPad, this would require a minimum of two apps, one for each task. Though it's possible that task #2 might be the only one you need to worry about, depending on answers to some questions:What is a comparable alternative for mainstage 3 that I can use on an iPad. This would be used in live performances. Most important are a wide variety of piano, keyboards, etc. as well as some orchestra strings horns, etc. Thanks
* will all your sounds be coming from the iPad? Or will you also be playing sounds that are built into your keyboard (or some other MIDI source)?
* will you be playing only one sound at a time, or will you be splitting/layering multiple sounds?
* what keyboard(s) will you be using to trigger your iOS sounds? Specifically, what kind of MIDI functionality does it have? i.e. a keyboard that has MIDI zoning and the ability to send definable MIDI Program Changes built into it will demand less of your software choices than a keyboard that does not.
Depending on your answers to those questions, one app may do what you need, or you may need two or more apps.
Yeah, I saw a page that claimed MainStage 3 was available to download for free on an iPad, but carefully reading the links on the page clearly showed that it was for macOS, not iOS! And then I found an Apple Support page that said you can use an iPad app to play MainStage instruments, but it's just accessing MainStage remotely on a Mac using the Logic Remote app for iPad. As far as I can tell, you need a Mac to run MainStage or Logic Pro, but if you are doing that then you can also access the instruments on your iPad-- except I'm not sure whether the iPad is truly accessing them, or just acting as a touch-sensitive controller for playing them remotely on your Mac.
