Well, I’ll explain later why I’m referring to this particular keyboard but it’s about the Kawai MP11SE.
It weighs 34 kilograms, and the spider pro can handle 35 kilograms per tier...
Obviously, I’m referring to the bottom tier...
I would not think that any Engineering load calculations are undertaken during the design process.
More likely that the company build a prototype and then load it with well in excess of a trio of heavy keyboards then they probably leave it loaded overnight.
So yeah a safety margin is inbuilt during the testing.
There again if the likes of Onstage have a finite element analysis software then it can be loaded in the computer before a prototype is constructed.
Either way there would be a physic test which may even include a test to destruction.
