ME-80 pedal on keyboard
Has anyone used the ME-80 pedal on a keyboard? If so, does it function well in all registers? How does it sound with, say, an organ or electric piano sound (or for that matter, how is it in general)?
Since it is geared toward guitars there is probably not a whole lot of experienced users using this with a keyboard to give you a real good opinion. If you are looking for opinions in order to form a judgement around a purchase I don't think you will get enough feedback to base a buying decision on. My two cents.
I have a GT100 that I use with my Gibson Les Paul and Ibanez guitars which I connected up to my Korg when a similar question was asked a couple of years ago.
It worked OK but it is not as though I did extensive testing.
Do remember the available dynamic range of a keyboard is much wider than that of a guitar especially in the bass.
