Page 40 of the manual. You need to save the program. See #7 below. Sounds as though you are not saving (writing) the program; so when you power off the keyboard your changes are lost. You have to save the program with the changed effect; most likely then you will have to recall that program when you start up the keyboard then that program will have the changed effect.
