- Joined
- Jan 10, 2011
- Messages
- 2
- Reaction score
- 0
Midi Controller Keyboard help needed please!
Hi all,
I'm looking for help choosing a new midi controller keyboard.
I need weighted (poss. semi-weighted) action, 88 keys and at least a couple of controller sliders/faders.
I know the M-Audio Oxygen is the obvious choice but it's expensive at £500+ and has lots of knobs that I really don't need. I actually generally only need pitch bend, mod, volume and expression.
The M-Audio Keystation is much cheaper at around £175 but only has one slider, and I need two minimum.
Another idea I had was to buy the Keystation (or similar) and the Novation Nocturn (or similar) for £69: http://www.novationmusic.com/product...roller/nocturn
Will this make things more complicated midi-wise? Or simpler because it's already setup for use with Logic?
Is there anything similar to the Nocturn that has faders rather than rotary controllers?
This is for studio use, but I am a pro keyboard player hence I need something with a good action and 88 keys.
Any help would be much appreciated
Jamie
Jamie
