Hi all,
I am curious about what midi data gets transferred when you use a keyboard as a midi controller. I believe that if you hit a single note on the keyboard then midi data is transferred that tells which note was played and how hard it was played along with other data about the note. I begin to be less sure of what is transferred when you play a chord or a chord with melody notes at the same time.
The reason for my question is related to live performance.
I am wondering if you are using an arranger keyboard as a midi controller if midi data is being transferred from the voices of the “style” being used as well as anything you are doing with the right hand.
I hope my question makes sense. Thanks in advance for any help.
