I’ve been using a PC for editing midi files for a couple years now using Power Tracks Pro. It worked wonderfully, but there’s no version compatible with MAC. I tried using a program that allows you to run PC software on a MAC but there’s no audio output selectable within the program.
Most of what I do is remove volume controls, pan everything (except click) to the left, remove instrument assignments for the tracks, and add a click track (this was very convenient in Power Tracks because you’d just open up the metronome and click the button that said write to track)
An event list editor within the program is crucial for me.
The best option for me would be to be able to use my software on the MAC but would be open to using a new program that could do all the afore mentioned without having to break the bank.
These are for backing tracks for live music.
Any help would be greatly appreciated. Thanks
