Midi files via usb
i have Yamaha PSR I455 keyboard. when i play the midi songs via usb the tabla voice is not coming together with other sounds. is there any extension files to get tabla voice on my key board while playing.
If you want a MIDI song file to use a particular voice or drum kit on your keyboard, you need to be sure the MIDI song selects the desired voice or drum kit by the correct Bank Select and Program Change values. There is a free "MIDI Revoicer" utility at http://www.jososoft.dk/yamaha/software/revmidi/index.htm that you can use to change the voices and drum kits that a MIDI file will use. However, be careful that you subtract 1 from the Program Change values that are listed in your Owner's Manual, because Yamaha numbers them from 1 through 128, whereas the computer numbers them from 0 through 127.
No, there's no function for playing MP3s on the keyboard.
