- Joined
- Dec 24, 2013
- Messages
- 16
- Reaction score
- 0
Hi all, need some help.
I have an acoustic piano with the AnyTime computer connected to it. This allows you to throw a lever on the piano and use it like a synth. It has three stock sounds (piano, harpsichord and sorta an organ). You're supposed to be able to be able to hook it up to other MIDI devices like sound modules and sequencers, but the owners manual is not all that helpful to me. So what I'm trying to do is output a piano note, into a Yamaha keyboard, and output the Yamaha sound to a speaker, effectively using the Yamaha as a sound module. This is supposedly possible according to the manual.
Anyway, I can't get it to work. So, let me ask you all this, how would you hook it all up if you came over the house today after having your Thanksgiving dinner?
The AnyTime computer has these connectors: MIDI IN, OUT and THRU. Left/Right 1/4" Line IN, Left/Right 1/4" Line OUT and two headphone outs.
The Yamaha keyboard has a MIDI IN and MIDI OUT along with a 1/4" Line OUT.
This should work!!!! So far I can get the acoustic piano to output its note to the keyboard and the keyboard to the speaker, but the sound of the note is always a concert piano. The Yamaha tone that is selected is never output using the piano keys (only from the Yamaha keys). This seems wrong to me considering the manual for the AnyTime computer talks about adding a sound module to expand the selection of sounds from the stock 3.
Can anyone decode this equation for me and explain how this should work? I will have dessert ready!!!!
Happy Thanksgiving all and enjoy the holidays.
