- Joined
- Jun 20, 2017
- Messages
- 15
- Reaction score
- 1
Prefacing: I have done a search and cannot find what I am looking for, but if I missed it and you want to respond with a link, thank you.
I am using this rig for live performance:
HP Laptop
OS: Windows 10 with the latest updates
Controller: Arturia Keylab Essential 61 MKII
Software: Arturia Analog Lab
Interface: Lexicon Alpha
The controller and interface are usb to the computer.
The only other application running on the computer is a pdf reader for charts.
I am only using analog synth sounds, but some are layered.
As the title suggests, I am getting a bunch of hung notes. I am trying to trouble shoot this, but not sure where to start. I have reached out to Arturia, but so far their remedies have not worked. There is also a little language barrier and I can tell some things are getting lost in translation. So I turning here in hopes of finding a possible process for hunting, and more specifically what I am hunting for that causes this. I know a midi note off command is not making it through. Are there apps that let you record the midi commands? I think Arturia is thinking that the CPU demand could be the issue, but I just don't want to believe that. There is not much running. Would a two synth layered sound task the cpu great enough to cause this? It is to the point of being unusable. Maybe I should rephrase a question to ask what could cause this?
Layered sounds?
Too many notes at once?
A combo of both?
Any help or, as I mentioned, link is welcome. I have no problem putting in the time, but what I am seeing mostly is trouble shooting hung notes through a host using VSTs. This is not that. Analog lab is a standalone application. I can make set lists within it. Thanks
HP Laptop
Layered sounds?
A combo of both?
