- Joined
- Jul 15, 2022
- Messages
- 4
- Reaction score
- 1
Hello, and thanks in advance for anyone responding.
I have an MM6 Yamaha that I will soon be replacing the display screen on. While I'm in there, can anyone tell me if there is some type of internal battery inside, that should be replaced? I see many people mentioning that replacing the battery (if it does have one), means losing stored data of some sort. Has anyone ever tried jumper-ing the battery terminals while making the switch to avoid this? Do you think that would work?
Again, thanks in advance for any response or advice.
Pete
Pete
