MODX mystery On Elements Not Making A Sound
I have noticed oftentimes I will go into a sound and when I go into the elements I will solo each one to hear the sound but not all of them with a green light when played make a sound, I have gone through the different tabs on the left ( Osc/Tune, Pitch GS, Filter, Amplitude, Element LFO) and see no effective difference to make them silent. I only see one is a different preset number at top of Osc/Tune tab. I can't figure out why some elements are muted and making no sounds on solo setting.
In these diagrams , element 2 makes a sound when solo, but element 1 does not, why doesn't element 1 make a sound?
Check the individual volume levels settings for each layer in the setup.
I assume there's some sort of mixer and FX panel for the elements?
Check the Element EQ and Amplitude settings.
i'm not talking about the performance parts. I'm talking about the elements within each performance sound.
Select a performance then hit "edit" on the performance and it shows the screen above as I indicated.
Amplitude is marked on the left side, smack dead centre.
That is pretty self-explanatory. I'd say.
EQ settings also have loads of effect on a sound wave.
Change a few of those settings and the missing harmonics should be blasting you.
per OP:
"I have gone through the different tabs on the left ( Osc/Tune, Pitch GS, Filter, Amplitude, Element LFO) and see no effective difference "
I can tell you don't own one. As for logic, there is none in any of them , they are only as designed the way someone else imagined things to be.
One final brain fart.
Any chance the individual layers/voices/elements/whatever are simply not assigned in that setup/scene/preset/whatever?
How can you tell if it's an empty slot?
BTW... The recent inrush of Yamaha people, to me, is akin to a satanist coven crashing a church picnic these days... :)
No offense. To me Yamaha has always held a warm spot in Hell. :D. :D. :D
Burn me once. :p
On Topic: Well happyrat you were right, i double checked the amplitude setting and found it was '0' on that one element , don't know how i missed that.
Semi On Topic: I will say I am really impressed with the MODX, sounds and flexibility to accomplish a lot of things. Its not always easy to get a sound but I have had good results with the sounds I have gotten trying to cover other songs. The Scenes feature is really nice. Just wish the 76 key had more weight on the keys.
Off Topic: Yamaha = hell? What's next Hitler supported Yamaha? I got mine cheap in the aftermath of the initial release which is how I get all of my keyboards but I am an equal opportunity brand fan, I have big respect for Roland and Korg too.
My beef with Yamaha is that they refuse to adhere to the USB/MIDI class comparability standard. For decades I worked with a Linux platform and Yamaha basically told me to pound sand when it came to Linux drivers.
Nowadays Yamaha is the antichrist when it comes to my music. :p
Glad you found that amplitude setting ;)
Midiaccordion
