- Joined
- May 16, 2020
- Messages
- 17
- Reaction score
- 1
I was liking what I heard from the keyboard player from Mike & The Mechanics. Also, I liked what I heard in store.
What do you think?
What do you think?
They really don't talk much about MODX over at Motifator, because it's not a Motif. The best MODX-specific discussion area is probably the one at https://yamahasynth.com/forum/modx-1If you really want to hear the real details, warts and all about the MODX I'd suggest asking over on Motifator:
Highly subjective! Each board has its pros and cons.the keyboards at a similar price point that are made by Korg and Roland are better...Kross 2, Krome, Juno and FA, I would buy any of these in preference to a MODX whose menu system is dire, controls lack feel and for the carbunkle in the middle of the buttons it just not fine enough in its control.
h.com/forum/modx-1
Something can be balanced and still be subjective.Not subject at all, a balanced view based on use
A mix. The fact that FA has a full sequencer, for example, is objective, but quality of voices is largely subjective.Is that subjective enough with the Pros and Cons?
There may be one or two people on the forum who own a MODX but I haven't seen any of them here on the boards for quite a while.
If you really want to hear the real details, warts and all about the MODX I'd suggest asking over on :
motifator.com
motifator.com
To be more accurate, "you can't have a midi controller as a second board and play multiple sounds off the MODX" simultaneously with playing different multiple-part sounds on the MODX itself. A single-zone controller CAN be used to trigger multiple sounds (parts) of the MODX in other cases, i.e. where you are only playing a single different Part from the keys on the MODX itself, or if the MODX' own keys will be playing the same Parts as the external keys, or playing no Parts at all.problem with the MODX is the lack of decent midi implementation for internal sounds. Unlike virtually every performance keyboard and workstation in the last 30 years, you can't assign multiple sounds to one midi channel. What this means is that you can't have a midi controller as a second board and play multiple sounds off the MODX unless your controller keyboard has multiple zone capabilities.
Actually, no, in such a 2-keyboard setup, you still only have to change presets on your MODX. Remember, when you have it set like this so that each of the two boards can trigger multiple MODX sounds, the MODX sounds will always be on channels 1-8. Let's say your second board is a 4-zone controller. Set it up to transmit on, say, channels 13-16. Now all you have to do is set up your dual-board MODX patches so that the sounds you want triggered from your external board are all placed within the range of Parts 13-16 (leaving any of those that you don't need silent). Now calling up any of your dual-board Performances on the MODX will automatically assign each sound to the board you want it to be triggered from, over the key range you want to trigger it from.unless your controller keyboard has multiple zone capabilities. Then you would need to change presets on your midi keyboard for each different song as well.
Considering that it's different from the way they (and everyone else) has been doing it for decades, I don't think it was an oversight, I think it was intentional. The question is, why? My guess is that it has to do with the introduction of multi-part single instruments. For example, say you want to use a 4-part piano (i.e. one that takes advantage of this new architecture to permit a piano patch to have up to 32 elements per key). It does this through some internal remapping such that the keys are playing a single piano sound that spans parts/channels 1, 2, 3, and 4. If you could move channel assignments such that multiple parts of that piano sound were on the same channel, it might break the piano sound (additional wrong elements triggering on some keys or at certain velocities, etc.). That's just a guess, and even if it's right, I don't know that such a problem would be insurmountable to code around, but it is something that might have led to the inability to move Parts and Channels independently.Major oversight, and it's in both the MODX and the Montage.
If the MODX/Montage is exactly the board someone wants except they must have that missing ability to have a single-channel external controller address multiple MODX parts/sounds while independently playing a different set of multiple MODX parts/sounds from the keys of the MODX itself, there is a workaround for this, by using a MIDI Solutions processor (or an iPhone or other iOS device, or laptop) to remap the single MIDI channel of your controller onto channels 9-16 of the MODX. Then, in all your MODX performances (patches), the internal keys will play your desired split/layered combination of parts 1-8 (which is the maximum you can set them to play anyway), and your external keys will play whatever split/layered combination of parts 9-16 that you want.the midi setup is the major problem I have with the MODX and Montage. If that's going to be something you want to use, then it's not the board for you.
Yeah, each company has its strengths and weaknesses in support, too. You're right that Yamaha could benefit from a library of official video tutorials. The best youtube channel for Yamaha Montage/MODX support is actually not from Yamaha at all, it's at https://www.youtube.com/user/papaphoenix/videos (French with English subtitles).In all fairness as I posted in other threads I watched video tutorials on both the Roland Juno DS and Korg Kross 2 to get a good idea of the menu systems before going instore to play them.
Whilst instore I had a play of the MODX, then when I got home I tried to find what Yamaha had to offer by way of tutorials. I found the Yamaha Youtube Channel on which there were two videos on the MODX, totaling less than 2 1/2 minutes. Is this the kind of customer care and product support any buyer wants, to have to work through the manual or layers and layers of menus to learn even the basics.
This additional info about what you're looking for is helpful.Thanks everybody. I had the use of a FA and it didn't have the best soundset for {scoring} and recording authentic orchestral parts.
I also was not pleased with the FA playing live. It was pulling teeth to get a simple bass/upper combo split. It could have been
my programming shortcomings, but I can find my way around other keyboards much quicker and easier.
Here's a better link to the MODX tutorials on their support site:I found the Yamaha Youtube Channel on which there were two videos on the MODX, totaling less than 2 1/2 minutes. Is this the kind of customer care and product support any buyer wants, to have to work through the manual or layers and layers of menus to learn even the basics.
Thanks everybody. I had the use of a FA and it didn't have the best soundset for soring and recording authentic orchestral parts.
What do you think?
