Most crucial computer part for DAW recording -
Hello, Everyone - for recording live audio performance and midi tracks into a DAW, where there may be DAW plug-ins and samples being used, what is the most crucial component of the computer system? Lots of RAM? processor speed? Processor threads? Hard drive speed?
I might be recording 2 to 5 lines into something like a Xenyx 1202USB, running into the computer to record one or a few tracks, then maybe add synthesizer by line in, or by midi. So, at the most I might have live sound running into the DAW from the mixer's USB, while also having midi tracks playing, or operating a soft synth in the computer at the same time. --Thanks!
Its not just one component.
Its how they all work together, but there is one that is more important than the others.
Work on 2Gb RAM per Processor core, a lot of laptops have minimal RAM.
So a quad core with 8Gb RAM and a solid state hard drive will serve you well, a SSD drive will boot very quick hence ideal for on stage use.
The one component that is more important than the others is the quality of the inbuilt sound-card.
Compatibility of the DAW with the soundcard and its drivers is probably the most problematic issue that anyone has.
I certainly tried a few DAWs and quite a few were difficult if not impossible to get functioning on my old but still fast laptop.
