Motif es octave change
Cleveland
Ok so i am going slightly crazy....
on the motif ex6, in performance mode, i need to change the octave of just one of the four patches... is this possible? i cant find anything about it in the manual or well anywhere. If you know how i would be greatly appreciative!
thanks a ton!
Switching it on the fly or just bump it up/down an octave and save is as that?
Those dedicated octave buttons switch the whole keyboard regardles of the mdoe you're in.
If you only need to bump 1 sound in the performance for a specific amount of half-steps, you can do it in the performance part parameters along with a lot more options.
