Multitrack recording on Casio WK-3300
Does anyone know how to record a track in real time, save it, and then add further tracks to it? Ideally saved to an SD card? The downloaded user manual instructions don't appear to work.
The Y_man
Melbourne, Australia
When you say the instrucitons don't work - what did you do (which stesp) and what happened?
The Y-man
On my WK-3800, you press the Song Memory button until it says Record 500 (500 or 501 is the number of the song). Then choose a style, a tone, press Start/Synchro and play, when you're done press Stop.
For recording the 2nd track in real time, press again Song Memory until it says record, press the Registration 1 memory (Bank), this way you selected track 2. Press Start and the song recorded on track 1 will play, and you are recording the 2nd track, press Stop when you're done.
Hi Vctor
Thank you for your reply.
I've followed your sequence 'to the letter' and whilst I can hear the the first track I record the second track doesn't record.
Just about to give up with it!!
Regards
John
Hi jt4music, the Registration buttons are the track buttons, I attached a picture.
After recording the Track 1, press Song Memory button until it says Record, then press the Track 2 button and then start playing or hit the Start button.
Nils Petter Roald
