- Joined
- Sep 2, 2019
- Messages
- 6
- Reaction score
- 1
Hi All,
Wonder if you can assist with advice. My daughter has just started her Music course today. She has had singing lessons for years and continues to do so as well as a member of the local amateur dramatics group which is free. She has never played an instrument before so she will also be learning to play as well.
Due to budget constraints we are looking to get her a entry level keyboard whereby she can record her singing as well as the output from the keyboard and then edit the content as well. I understand I would need to get a MIDI keyboard for this, is that correct?
We are also looking at getting her a 2nd hand macbook pro or air. I know the pro would be more suited to this but again budget constraints as I am a single parent father who works but is reluctant at present to spend out properly until we see more professional stuff is required.
We would probably be looking at software like Cubase Elements, unless you can advise of free software with the same caability which is free and MAC compatible
So I wonder if you could maybe point me in the direction of what we actually need that can do the above and do we need a midi? The course outline is below if that assists.
You will study the following units:
- Using a keyboard with a DAW
- Live music performance
- Session musician
- Planning for a career and getting work in music
- Life sound recording
- Music rehearsal skills
- Music improvisation
- Radio and podcast production
