Music rest for MODX8
I bought a Hercules BS118BB 3-Section Music Stand with Bag from Amazon.
It is expensive but top quality and sturdy.
I also have its cheaper brother a Hercules BS050B Music Stand, which is a lighter version that is OK for home use but I would not take this to regular jam sessions.
I think the OP might have been hoping for a music rest that can be attached to the MODX itself, but I don't know if its casing is designed with slots or screw holes or whatever for attaching a music rest.
A member of the PSR Tutorial Forum recently posted pictures of a tablet stand that he built for himself. It sits on the body (top panel) of his Genos keyboard and holds his iPad at just the right height and distance for its touchscreen to be easy to use without obscuring the Genos's own display/touchscreen. I imagine that his design could be modified as needed so the stand could hold printed sheet music:
Similar Threads
Rajitha
