MX-49 Performance mode override and arpeggios
This new MX-49 has been no simple task for me so far!
Here's dilemma 1 (and I can't seem to get any help from the manual): I want to save a new performance. Pretty simple, really; just part 1 and part 2. The problem is overriding all the presets for performance 3, as an example. I have figured out how to stop the rhythm from playing and obviously assigning 2 new parts is easy, but within the presets there are chorus effects, reverb and echo-type effects that I have not been able to find, so a rock organ sound has all the effects applied to it as the previously designed synth part 1. How do I get rid of everything in the pre-programmed performance and start from scratch?
Second quasi dilema: with a 1,000 arpeggios available, you'd think there'd be simply 1-3-5-8-5-3-1 type arpeggio but there isn't, not that I can find. The goal is to arpeggiate an organ to mimic this from Foreigner:
