I am trying to record direct to usb on my CP40 State piano and it keeps erroring out after 15-20 bars. Not consistently but most. Very annoying when laying down tracks. I have re-formatted an old usb, used a brand new one -- just don't know what the problem is. Anyone else have this happen ... and maybe a solution?
Hi, I had the same problem with my PSRS 910. I don't know the CP40.
Check if your internal memory has enough storage space. if not, download data on PC.
If recording midi to USB stick, (can't do that on my keyboard) but can save the midi on memory stick direct from internal memory.
a good quality fast writing speed, I use scan disk only.
USB stick needs enough space for data. Steer away from cheap and slow writing usb sticks.
I only use Scandisk memory sticks. I have done several perfect midi recordings and never had this problem again. Hope you can solve your problem.
