Hi to all the people in the forum, my first thread here.
I just bought a new Korg Nautilus last december. Everything was great....until a couple of days ago. I recorded a few songs (up to number 24). When the problem started, I first got asked whether I want to save or discard some audio files in the Temp folder. Initially I went for save (Second time I discarder, but got the same effect), then when I opened the song menu in the sequencer mode, everything went freeze, and the only way out was to force shutdown. All other modes work fine, it seems to be related to sequencer.
I tried the following:
-work on preloaded songs: they all work fine.
-let the frozen menu for a couple of hours, nothing changed. NOTE: keys don't sound.
-reloaded all songs in the same positions. I could open some of my songs but when I try to switch to another one, it goes freeze. NOTE: in the Media mode I can only see audio and track folders up to song 18, the remaining ones are still in the song menu but I have no idea on where their data is stored.
-initialize the song. The window opens, but when I go "OK", it starts idling forever....freeze and forced. NOTE: keys do sound.
-save the songs (both internal drive and USB drive). The window opens, but when I go "OK", it starts idling forever....freeze and forced. NOTE: keys do sound.
-overwrite some audio tracks. One weird thing I've noticed while try recording, the bars counter was stuck, only the bar movements was cycling. Anyway, it didn't work either.
Blame on me that I didn't save the songs one by one. Anyway, this is not a tragedy, I could try to restore factory settings and restart working on those songs, but before doing that if someone has any idea on how to fix this, or at least save my work, is more than welcome. Most of all, I hope this is not related to something worse with the OS.
My set up is:
Phones: headphones
Output LH/RH: small speaker set with sub, RCA inlet.
Output 1-4: empty
Line 1: jack (Mic)
Line 2: jack (Guitar)
Pedal: empty
Switch: standard switch pedal
Damper: Quiklok damper pedal
MIDI thru: empty
MIDI out: empty
MIDI in: Korg i3 AT (1993) (Problem stays whether is on or off)
Thanks in advance!
Paul
My set up is:
Phones: headphones
Output 1-4: empty
Line 1: jack (Mic)
Pedal: empty
MIDI thru: empty
MIDI out: empty
Thanks in advance!
Paul
