Need help
have been playing Live and find it so annoying and unprofessional that when switching created sounds in live setting play mode there is a sound cutout, for such an advanced instrument, this should be able to be fixed but Am yet to find a solution. Please help
You dont speak to a model #; it may turn out that your keyboard may be a newer instrument but not necessarily an advanced one. My Kurzweil flows from one instrument to the next without a break in sound. Back in the 90's I owned a few Ensoniq keyboards and the voice muting was an option, meaning you could turn the feature on or off. These instruments are professional keyboards. Yours may not be, hence the issue.
You can't make a pig fly without a million dollar airplane either.
Some things simply can't be done.
Something to add to your shopping list next time you buy a keyboard.
Or just learn how to play around it.
Lot's of pro gear out there has this flaw, but it doesn't stop a lot of bands from using them.
Rajitha
