- Joined
- Feb 14, 2018
- Messages
- 209
- Reaction score
- 67
OK - My Live rig is kind of set for now. Bottom is my RD2000, Top board is a Fantom 7. I have a 3rd tier shelf with Legend EXP, Virus Ti2 and Peak. They all provide something the others dont - and in a live band mix the fact there is no fully analogue synth doesnt really matter.
When I say "set for now".... i want an Iridium BUT this will replace the Virus. I think it will do everything the Virus does plus sampler, FM engine (kernals) etc. The sticky point for now is the arp/sequencer doesn't latch when using an external keybed - only if using the onboard "pads". Thats a deal breaker for me but Im sure it will be sorted in a FW update - then ill make the switch.
so - id always thought thats would be it - literally no room for anything else HOWEVER, Ive re-giggled things. Ive removed my 3 tier stand from my home setup (keep it packed for live) and gone back to my old table 2 tier stand (more stable) - and Ive added some angled wall mounts to hold the 3rd tier while at home. The upshot is because Im using wall mounts - I have space for a 4th tier above it.
This will house "home use" only modules (no keyboard). its not limited to sound sources. Im open to drum machines, hardware sequencers etc as well. The caveat is I want at least one fully analogue synth. This is where the help comes it. Its partly about narrowing down the options with an "open eye" - no "pre conceived" thoughts. I dont know enough about how things complement or duplicate.
Options im looking at:
1. Deep Mind 12.
+ points: cost: analogue: control sequencer (means I can design a melody and transpose it in real time - something I cant do). FX
- points: DCO not VCO (not convinced a DCM is any better than a hybrid like the Peak in its core sound). Limited Osc section.
2. DSi Rev 2.
+ points: its a DSi.... loads of modulation and full Osc section.
- points: DCO not VCO. Cant transpose the patterns without holding a button at the same time - not great for me.
3. Argon Cobalt 8.
+ points: price. Full Osc section. Nice sounding.
- points: its another VA
4. Profit 6/OB6 ()probably the OB as its less like the other things I have/am looking at).
+ points: VCO. NICE sound.
- points: Limited flexibility (does that matter with everything else I have). Cost
5. Keystep/Beatstep Pro.
+ points: can do those transposable sequences DM can - but multiples running at once.
- points: no sound in itself. difficult to integrate over Midi (need to insert/merge it somewhere in the chain)
6. TR8s
+ points. Adds rhythm stuff I dont have (well I do on the Fantom but its pattern based not real time)
- points. Its not a synth lol.
Im more than open to other options I may not have though of - or alternatives to kit Ive listed. Polybrute module would definitely be up there - but I haven't heard of any plans to release one.
Size wise - I have 400mm deep which is plenty - possibly enough to stack one behind another (beat step and Tr8s for instance, though Ive not checked sizes). Width wise, the shelves are 120cm - so plenty for 2 modules. Possibly 3 with a little overhang, and depending on the modules (cobalt 8 and DM for instance arnt big).
As I say - I know what Id like - but thats not what I want to do lol. I want a selection of gear that allows flexibility, as wide a range of options and capabilities I can, though as I say i do want a fully analogue synth as I done have one ( and Ive never had one).
so - long post - but help?????
1. Deep Mind 12.
2. DSi Rev 2.
3. Argon Cobalt 8.
6. TR8s
