- Joined
- Jun 2, 2021
- Messages
- 39
- Reaction score
- 15
Hello KF, if you are interested in using the Korg PA 5X for dance music and EDM, I recommend checking my youtube video for the most up-to-date EDM Pack expansion included samples, that cater specifically to electronic dance music. For dance music and EDM, you'll likely find a plethora of electronic and synth sounds, Pads, Leads, Pianos, and other relevant samples that can be used to create electronic dance tracks. The sounds you hear on the Video demo is only from KORG PA 5X. Al sounds are compatible with KORG PA 4 X. Also check out The Platinum Edition for Pa 4 X and 5 X. Please contact us from www.globalsound.se Best Regards Global Sound Team |
_________________ www.globalsound.se |
