New to keyboards
Hello, ok, ive got a little problem here :) i dont have any experience in playing keyboards-pianos or using them at all, only guitars, but i want to buy one and learn it.
Price range - dunno, i live in europe-lithuania, so the prices may be different from what you could advice me to buy, so lets have it like 500$-1000$+. Main things that i want is comfortability while playing and nice piano - strings and choirs sounds, by the way, what kind of things i should be watching over before buying one ? Models that i could get at local shop are Roland GW-8, Yamaha MM6, Roland E09, and i tought about asking would it be possible to get Korg tr61. Oh, Edit post : While reading up the forums i understood that the Korg TR61 would be the best from these to get...
There are TONS of posts regarding the same issue already on the forums, so you can get lots of info there.
But yes, from the keyboards you mentioned - TR would be the best choice
And that your opinion would be for Korg M50-61 ? ive jost got message that its impossible to get TR model, but they offered me M50-61 for 1100$
Yea, it could be discontinued. Apart from the fact that the M50 lacks a sampler option - it's better then the TR in every other way
crafterofpixels
