...just playing with some midis from the SD card using the mixer controls. When modifying the balance or taking out the main lead line...can you save it back after rename to the card or on the keyboard as a modified file ? (Casio WK7600)
One big hint is to download the PDF manual (like we just did to tell you these things).
The big advantage over the paper one is that you can do a word search in adobe reader.
