No sound, Yamaha PSR-11
Hello, I just got a Yamaha keyboard from someone who was the previous owner of the keyboard. She said it worked and everything. I have plugged it in and turned it on but I can not get any sounds out of it. Should I get it checked? Is it broken? Any ideas are appreciated
Welcome.
The 11 is a very old model and probably not worth spending any hard earned cash repairing.
There are dozens of posts here about various Yamaha keyboards with no sound, if you do a search and work through the suggestions on your 11 until you cure it or find no cure.
Also check the Function Menu, on qute a lot of Yamaha keyboards the speakers can be turned off and on via a menu selection.
If all else fails reset the keyboard and clear the onboard flash memory.
