- Joined
- Aug 26, 2022
- Messages
- 29
- Reaction score
- 3
hi all, I just got a 88key nord and need to get a travel case -- of course the Nord brand case is 700$ UGH!
can anybody recommend a more affordable case that does the trick protecting this board? I do worry about the knobs breaking off, etc? you know?
is the NORD case worth it? or is there a more affordable one you recommend? ideally it would have rollers on it for easy transport and im thinking a soft case, as the hard cases are so damn heavy.
any advice is appreciate. thank you!!
