What is the easiest way to get my CKF files on the computer, listen to them, edit them, and convert them to wave... or anything? Casio's data expansion system is alright, I can add user tones, backup my work and all that crazy stuff but their wave converter freezes up everytime I open it. I have a pretty good computer too. Vista says NO.
I've tried atleast a dozen audio converters and none of them (unsuprisingly) were compatible with CKF. If converting a prerecorded song isn't going to do the trick what is my next best option? I've read most of the recording music thread but is there a better way? If I'm stuck doing it the old fashioned way, is it possible to do without the male/male adapter? I'm equipped with an M-Audio Midi converter and elbow grease.
So I realise that my single question branched off into way to many questions... I was thinking outloud and typing everything I was saying. My apologies. In the end, all I want to know is the easiest way to rescue my songs from the burden that is CKF.
