- Joined
- Nov 24, 2021
- Messages
- 9
- Reaction score
- 2
Hey all,
I've got a Kurzweil SP6 and a Yamaha P90 connected via MIDI (OUT of the Yamaha, and IN to the Kurzweil). I have a sustain pedal connected to my Kurzweil, as this is my main board, and I would like it to control the sustain on both keyboards at all times. When both keyboards are on the same MIDI channel, it works for both, but in order to have the Yamaha play one program, and the Kurzweil play another program, I need them on different channels.
For example, I like my Yamaha to either be a KB3 or a synth, and my Kurzweil to be a grand piano, so I make the Yamaha transmit channel 1, set channel 1 to the KB3 on the Kurzweil, then I switch my Kurzweil to channel 2 and make it a grand piano. Once I do this, the pedal no longer sustains notes on the KB3 (the Yamaha).
Anyone aware of a setting that would make my pedal function simultaneously across MIDI channels? It's really annoying to have to switch to a second pedal, plus, it leaves me without sustain on one of the boards when I am playing with one hand on each.
Thanks!
Brandon
Thanks!
Brandon
