Only one end of keyboard plays
Hi there, just wondering if anyone can help me on this one. I'm completely new to keyboard playing so any info would be welcome. I have a Yamaha PSR 220 and can only get sound out of one end of the keyboard. It was working fine for a while, then nothing. Thanks :)
Well sounds like you have a short some where in the system.. Also you can check to see if your keyboard has split mode where you split different piano's together, if you do just turn it off..
Try a reset, hold down the highest white key (C5) while powering up the keyboard. And also as mentioned, see if the keyboard has a 'splitpoint' that by accident has moved. Does it has an acc on/of button?
It's possible that the keybed is a two piece keybed with each half having its own connector and one of the connectors needs to be reseated.
Mendelw
