I have Yamaha DGX-500 keyboard that has tuning issues. The tuning across octaves is not the same, particularly the upper three octaves. I have reset, set the pitch bender to zero and re-tuned in an effort to resolve this problem, and confirmed the issue with a digital tuner. Re-tuning -5 partially resolves the issue on the higher octaves, but negatively affects those below middle C. This problem is most noticeable on the piano voicings. I have a friend with a similar model with the same problem who tells me that I need to add the batteries, even when I am using the AC power supply. That sounds illogical because the battery circuit should be disabled when the power adaptor is inserted. I have been able to find any information regarding this problem or an effective solution on-line.
I have had other piano keyboards that never had any similar tuning issues. Has anyone else ever experienced this with a Yamaha?
