I use a p-125 on gigs, and have read that the triple-pedal setup for home models will also control Leslie speed for the organ voices. I contacted Yamaha to inquire about something for the non-home p-125 and was told nothing exists. Ideally, I only want to get the plug for the switch and find a switch to perform the same function (Leslie on - off). Any suggestions? Am I further ahead buying the unit (about $85), then remove the two legs and make a new floor rest? Appreciate any ideas.
