I connected my PA1000 and my PC to be able to use PGMusic Band in a box and PowerTracks. I installed the Korg MIDI USB driver and I can play on Band in a box Midifiles which use Korg PA sounds so the connection works, at least in one direction!
However I would like to record a melody from my Korg to add to a midifile created on Band in a box
I believe there is something that I am missing on the PA1000 side to make it work... Anybody has some experience connecting the PA1000 and a computer based DAW? Thanks in advance
J-Louis
J-Louis
