PA5x Matrix Settings recovering after OS 1.3.1 Update
Athens - Hellas
After every Pa5X OS update you have to save your Custom Resources.KST , update OS and then reload
your Custom Resources.KST back as installation manual says but they forgot to mention one significant
detail , Settings of newer OS v.1.3.1 are not compatible with previous OS v.1.2 and the result after
reloading your Custom Resources.KST are to lose all Matrix & KAOSS preset settings ...
Pa5X users with custom resources that you have upgraded to OS v1.3.1 and you then had loaded your
previous Custom Resources.KST do the following to restore preset settings of Matrix & KAOSS.
- Go to FILE/Menu/Factory Restore , uncheck all , click only at SETTINGS square box , restore and Done.
Your whole KST custom resources will be untouched ...
Then you can set any custom Global settings you had done in your previous setup.
Hope this helps
Antony Sharmman
BTW : this post was made 2 days before my approval and before other members had posted my answer at forum.
Nils Petter Roald
