PC3LE7 haunted pitch bend
My pitch bend seems to have taken on a mind of of it's own. Several times a minute it bends up and down without me even touching it. it used to do this only once a month, now I can't make it through a song without this happening. Does anyone know where / how to go about turning off the pitch bend function internally if possible?
Thanks in advance, Sean
Midi mode, the transmit tab, you'll see the control setup, usually it is set to 126 Internal voices. Edit the control setup and set the pitch bend to off or zero in both directions. Save.
In some cases you can get temporary relief by 'massaging' the pitch bend. Accomplished by holding it down and let it flick up then holding it up and let it flick down. Do this about 50 times both directions. Some users have reported getting temporary (months) of relief.
Similar Threads
